メインコンテンツにスキップ
2018年10月26日発売。モデル番号はA1984, A2105, A2106, A2108。オプションとしてGSM もしくは CDMA / eSIM, nano-SIM もしくは dual-SIM / 64, 128もしくは 256 GB /カラーバリエーションはブラック、ホワイト、ブルー、イエロー、コーラル、レッドがあり。(正しい発音は"iPhone 10 R"です)
468回答 すべてを表示
iPhone keeps reseting and goes to 1% battery
I had problems with this phone and sent it to get repaired, it worked fine for a few days and showed that the battery is genuine. Now every now and then it starts to lag, resets and shows 1% battery and that the battery is not genuine and it wont show the battery health. Then it resets again and everything goes back to normal, and the phone says the battery is genuine.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Hi Noa,
Starting with the iPhone XS and XR, Apple started pairing batteries with the logic board. The result of this is that when you change the battery you lose the battery health information and you get the non-genuine part warning. There are two ways around this problem; first you can have Apple replace the battery for you and everything will be fine.
However, if you're not Apple and still want to replace the battery, you have to remove the BMS or Battery Management System from the old battery and transfer it to a new battery cell. The BMS is a small circuit attached to the battery that provides storage for the battery health and cycle count information and communicates with the motherboard. Nowadays you can buy replacement batteries that come without the BMS for the specific purpose of reusing the old one.
Once you've cut the BMS off the old battery and soldered or spot welded it onto a replacement cell, you're still left with the original health and cycle counts. On the XR you can reprogram that information with a device programmer like the JC V1S or the Qian Li iCopy.
It sounds to me like all that was done correctly when you had the battery replaced (assuming you didn't have Apple do the work), but now it's giving you problems. It sounds like you may have a problem with the BMS itself; that would explain the error messages you're getting. Unfortunately, if the BMS is failing then it will need to be replaced. If you don't have Apple do the replacement, you'll lose battery health and get the warning; there just isn't any other workaround for it.
It's possible the connection to the BMS is flaky so it would be worthwhile to go back to the shop that did the replacement originally and see if they'll check their work; hopefully they'll stand behind their repair.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This would be your phone receiving some kind of damage seen or unseen most likely the battery is completely gone I would recommend getting it fixed at UbreakIfix which usually costs around $100. I hope this helped :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Noa Gulic さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 37
