メインコンテンツにスキップ
5G搭載スマートフォンGoogle Pixel 6aの修理ガイド情報です。2022年7月に発売。
42回答 すべてを表示
Why is my phone won't turn on & can't connect with usb charging?
this happen while i am charging my pixel with off/turn off condition (22% live battery) , but suddenly when i'm checking back arround 30 minutes there is no sign of charging percentage and wont turn on when i press power button, or button combination in terms to restart the phone. any suggestion please? im very confuse right now. hope you can help me. thank you very much.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi Djaka,
In most cases where there's an issue charging the phone, the problem usually comes down to either the battery or the charging port, assuming you've verified that your charger and charging cord are both working. On the Pixel 6a you can help pinpoint the source of the problem by setting the phone down on a wireless charger. Since the wired and wireless charging use completely different circuits, that will tell you where the problem lies.
If the phone charges fine wirelessly but not when plugged in, then you've most likely got an issue with the charging port. Unfortunately, on your phone the charging port is soldered directly onto the motherboard and will require somewhat specialized microsoldering expertise and equipment to replace, so this would be a job to take it to a shop for.
On the other hand, if it doesn't charge with the wireless charger either, then that tends to point to the battery as the likely source of the problem, so if this happens and it was mine, I'd try replacing the battery as the first step toward fixing your phone. Here's the guide you'll need in order to do the job yourself.
Google Pixel 6a Battery Replacement - iFixit Repair Guide
You can also buy a genuine Google battery right here on iFixit as well; I'd recommend the Fix Kit, as it comes will all the tools and adhesives needed to do the job right.
Google Pixel 6a Battery - Genuine
Good luck; let us know how it goes!
Google Pixel 6a Battery - Genuineの画像
製品
$32.99
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
This is the same thing that happened to my Google Pixel 7 Pro what fixed mine was the charging port was completely bad and I unknowingly kept plugging it up thinking its not my port by me doing that I fried my battery and the last bit of my charging port. So overall check the charging port and battery. Hope this helps. :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Djaka Arrazaq さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 18
今までの合計 140
