Pc goes on but no signal
Hi,
Few months ago I built a PC and it worked fine when I tested it. Today, I come back to it but the pc doesn't work anymore. The only difference between those tests is the CPU cooler, which I had previously taken from another PC to test this one. First thinking the new cooler was the problem, I tried 2 different coolers but none of them made it work.
The pc turns on but there's no display, the leds which indicate problem (i don't know how those are called) don't turn on, I don't hear any beep. The only visible problem may be the fans which spin super fast and are petty loud.
I've tested all the components in other PCs and they all worked fine. I rechecked numerous time the cables inside the PC.
During the few months the PC was not moved, it was in a dry space and stored in a closed box.
If someone have a solution I can try, it would really help me out, thank you
Before we get too far into the diagnostics, can you give us the rundown of what parts your rig is using?
Alisha C さんによる
In the PC there's a :
- i5-9600kf
- TUF Z370 PLUS
- CORSAIR VS550
-G.SKILL TRIDENTZ 2X8GO 3200Mhz
- TUF 2060
- HDD TOSHIBA
- SSD OCZ
- I also put in their a WiFi card but I don't know the exact reference
Etienne de Brem さんによる
@etiennedebrem
Just confirming that there is a system speaker connected to the motherboard system panel connector as seen on p.1-17 of the user manual
The speaker may look not like this one but the speaker cable plug will be the same as it has to fit correctly onto the motherboard's connector header pins
jayeff さんによる
