メインコンテンツにスキップ
The Infinix Hot 10i is an entry level smartphone with a 6.52 screen and a 6000 mAh battery released May, 2021.
Display does not show
Display does not show anything
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
hello Shedy willy
If the display of your Infinix Hot 10i is not showing anything, there are a few things you can try:
  1. Check if the phone is turned on: Press and hold the power button for a few seconds to see if the phone turns on. If it does, but the display is still not showing, move on to the next step.
  2. Check if the display is damaged: If your phone has been dropped or has suffered any physical damage, it's possible that the display has been damaged. In this case, you may need to replace the display.
  3. Try a hard reset: Sometimes a hard reset can fix display issues. To do this, press and hold the power button and the volume down button at the same time for a few seconds. Release the buttons when the phone vibrates and then immediately press and hold the volume up button until the Infinix logo appears.
  4. Check the battery: If the battery is low, it's possible that the display won't turn on. Charge the phone for at least 30 minutes and then try turning it on again.
If none of these steps work, you may need to take your phone to a repair shop to have it looked at by a professional.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
not showw a display and sound
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
shedy willy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 765
