dots on screen when touchscreen is enabled
if i enable the touch screen i am getting dots on screen
Hello Sileti Imports
If you are seeing dots on the screen when the touchscreen is enabled on your Samsung Galaxy Book3 Pro 360, it could be a hardware issue with the touchscreen itself. The dots may be caused by dead pixels or a malfunctioning digitizer.
Dead pixels are pixels on the screen that are stuck in one color and do not change when the rest of the screen updates. A malfunctioning digitizer can cause inaccurate or erratic touch inputs, which may result in dots or other artifacts on the screen.
If your device is still under warranty, you may want to contact Samsung for assistance with resolving the issue. Alternatively, you could take the device to a certified repair center for diagnosis and repair.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 8
過去 30 日: 30
今までの合計 532
