メインコンテンツにスキップ
2017年8月に発表されたGalaxy Note8は、バッテリー騒動でリコールとなったGalaxy Note7の後継機種です。 Note 8は、2017年の9月に発売されました。
148回答 すべてを表示
Where to get a replacement charging-port (USB-C) assembly?
I got a Galaxy Note8 phone, and lately I have had problems connecting the charging/data cable (tried several different ones). The connector seems like it's connected, but the connection is wonky (especially when trying to transfer data) and it falls out if you look at it wrong. When trying to charge, I often get the "not charging correctly" error. As I need to replace the battery (real!) soon anyway, I'd like to replace the charging-port assembly at the same time. I understand the jack-contact is modular and can be swapped over to the new assembly.
Anyway, may real question is where can I find/source a (preferably new) replacement charging port assembly? I couldn't find it for sale here (unlike the battery). I'd rather pay a bit more to get it from a reputable source, than from some dodgy dealer on Amazon or eBay... And I need it shipped to Europe.
Is this something iFixIt could get for me from a reputable source?
PS: In a pinch - if it was available from somewhere - I could change the actual USB-C port contact if it's at all possible... it wouldn't be the first time I soldered SMD components...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @koppe
Here's just one supplier that may be suitable.
If not search online for GH97-21078A GH97-21067A to find suppliers that suit you best.
If you wish to replace the board yourself, here's a video that may help.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Sounds more like your charge port is full of dirt and needs cleaned out. Use a needle to gently work round the bottom of the port keeping away from the centre post. Lift any dirt out, the do either end to remove any left over from the sides.
さんによる
コメントを追加
回答を追加する
Koppe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 56
