メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sonyのワイヤレスノイズキャンセリングオーバーイヤーヘッドホン「WH-1000XM4」の修理・分解情報です。
I’m getting a high pitched sound out the right side randomly
Hi everyone. After having success with other repair help on here I figured it was time to tackle my headphone lot I bought. I mainly bought this lot for this pair of headphones. They work fantastically however I have a problem where randomly you can hear this popping that will turn into a loud high pitch like whistle almost.
I’m wondering if it’s a speaker that’s dying but I am honestly not to sure cosmetically they look great and I have been using them a bit in this condition with everything else going well.
To clarify the right side still works it’s not dead but this whistle sound will happen randomly and only happens over bluetooth
Any help is appreciated thank you guys
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
This is usually due to the microphone being dislodged/damaged. Temporary solution is to press the cup back in until it "clicks" (risk of damaging further so be careful) and/or turn off noise cancelling. I ended up getting mine replaced under warranty. There are some more technical guides available here though that might be useful in fixing the problem properly.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
And I probably would to I bought them out of a salvage lot a long time ago next question would you have any idea where to look for parts? Knowing the microphone is the problem is very helpful but unfortunately if that microphone is damaged I can’t replace it without a new one
さんによる
So after taking some additional research into it turns out its not the microphone but rather the glue from the pop filter that is causing the feedback loop. Did exactly that removed it and the problem was fixed took me 5 seconds thanks for giving me that tip for looking there
さんによる
Hi Jacob, thanks for updating with how you went, this post comes up when. People search so your information helps a lot. Glad to hear that fixed the problem!
さんによる
Hey Jacob, am very happy to hear you found a fix since I am currently dealing with the same problem. could you please specify what you mean by "the glue from the popfilter"? I haven't been able to find what that means.
さんによる
Hey Yasin,
figured out what the pop filter is:
- in the middle of the driver you find the feedback mic (below a small white cover)
- the mic itself is silver and has some black sticker on the opposite side of the wires. This is the pop filter.
- For me, on the side where I had the "popping" (and also a constant background noise), the glue of this sticker was leaking all around, almost looking like it's covered in earwax. On the other side it was perfectly clean.
- I removed that pop filter, cleared all the glue, and put everything back in place. I just hoped, that the bracket of the mic would also hold the filter in place.
Sadly this didn't help at all and I still have my noise/popping issue. But now we at least know, where the pop filter is.
さんによる
コメントを追加
回答を追加する
Jacob Ridlon さん、ありがとうございました!
統計データ:
過去 24時間: 23
過去 7 日: 143
過去 30 日: 789
今までの合計 10,928
