メインコンテンツにスキップ
2019年6月28日に発売された、VRヘッドセットです。
43回答 すべてを表示
Headset completely lacking sound, Valve support says I can repair it?
Long story short, something about my HMD is wrong. Valve support won't help me much further than "you bought it from a 3rd party seller so we won't give you a new one but you can buy another one or go to iFixIt." The HMD does not produce sound. Not via the speakers nor the 3.5mm jack. The problem persists between computers, where windows says it is sending sound, but the headset does not receive it. What could I even replace to fix this problem? is it possible it's really just the cable and not the HMD?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
SOUNDS to be the cable.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I ended up buying a new cable from steam. It got here in like a day so that's neat, and the sound even worked again for a couple days after I plugged it all in, and now I'm back to square one. So maybe it is the headset...
さんによる
@cameronfowlks - Hmm @jayeff Lil' help here?
さんによる
@beanman56
The OP says that Windows is sending audio so I assume that means that it is communicating with the headset OK i.e. it has detected it, installed drivers OK etc.
Don't know the headset but looking at an image of the cable it appears to be a USB-C connector at one end and a USB-C, USB3.0 and a 3.5mm socket at the other end
If audio is supplied via the cable and the cable has been replaced, check what the cable plugs into in the headset is not loose or damaged.
さんによる
You've find a different tether than the valve index. It's power supply, display port, USB3.0 with a unique connector on the HMD side.
I guess I can pop open the headset to check out the connector though, thanks for the lead
さんによる
コメントを追加
回答を追加する
Cameron Fowlks さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 19
過去 30 日: 39
今までの合計 633
