What is the correct fuse?
What is the correct fuse to replace the old, that is burned.
Thanks
この質問は役に立ちましたか?
Thanks
この質問は役に立ちましたか?
If you changed the fuse three times and it burns out, you have a short circuit and/or overload in your system. The fuse is doing its job by protecting your circuits.
このアンサーは役に立ちましたか?
Look at the fuse side you will see how much the Amp on it and should the volt will be 110v-120v
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 776
2 件のコメント
What is the speed of your machine so I know which one you have?
mayer さんによる
I change the fuse, in 3 times it burned, in other time nothing happening...
Renan Andrade さんによる
