Instead of using the heat mat, can I use a heat gun...
Instead of using the heat mat, can I use a heat gun to take off the screen to get to the battery?
Yes you can. Apply heat around the edges then insert your opening tool freeing a bit of adhesive at a time. Then repeat until the screens off. Using some isopropyl alcohol as well will make the job a lot easier.
このアンサーは役に立ちましたか?
Do I need to use plastic picks? or can I use a spudger?
@nytryder26 I’d use a thin opening tool to make an opening then a thin piece of plastic. Plastic picks or a spudger might be too thick cracking the screen.
@strongbow Like this kit? iOpener
@strongbow Ok Ill check it out!
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 281
