Where to find 5,9 Ohm fuse resistor with 0,5% tolerance?
Does anyone know where to find the resistor shown on the pic?? It's from ps4 PSU, it should be 5,9 Ohm 0,5% tolerance. I can find it only on digikey, but don't want to buy 100 pcs. I have checked also AliExpress and ebay but no luck
@bender120 Do you know the wattage of the fusible resistor?
Andrew S さんによる
I had to order a similar part from digikey and was able to order a set of 10 voluntarily.
Dan Sayers さんによる
@andrewsawesome No, on digikey it says 2W
@dushku Do you have the link??
Bender120 さんによる
@bender120 what is the length of your resistor?
oldturkey03 さんによる
@bender120 No, it wasn't for the same part. The point was that digikey does not require a minimum order of 100.
Dan Sayers さんによる
3件以上のコメントを表示
