メインコンテンツにスキップ
モデル番号A1502 / 2.4, 2.6, 2.8 GHz デュアルコアIntelプロセッサ/ 2013年10月発売
552回答 すべてを表示
No power, adapter not lighting up
Sister gave me her 2013 macbook pro because she couldnt turn it on. Magsafe adapter is not lighting up at all when plugged in. Tried 3 different OEM magsafe chargers and none light up on her macbook. Chargers work because my wifes laptop uses them and is working fine. I tried SMC reset and unplugging the battery cable to power directly from the charger but it still doesnt do anything or show a light. Does this sound like the DC-in board?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
You would need to do some additional troubleshooting to know for certain, but it is possible that this is due to a failed DC-in board, although there's also a chance it could be due to a fault on the main logic board. If you can afford it, it might be worth ordering a replacement MagSafe board for testing. If that doesn't fix the issue, it's probably due to a fault on the main board and would require more advanced diagnostics to resolve.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
What further troubleshooting can I do to know for certain? Also the only DC-In I see listed on ifixit for this macbook is used for $14.99, that is definitely something I can try, as long as the used parts are good
さんによる
You could use a voltmeter to get the voltage read out from the pins on the MagSafe board when the charger is connected. This could help you confirm that the MagSafe board is working properly. With a 60W charger the read out should be around 16.5 V. You could also try to power on the system using an SMC bypass, to tell if the problem is due to a sensor on the logic board. To do an SMC bypass, disconnect the charger, hold the power button for about 10 seconds, connect the charger while holding the power button, then release the power button once the charger connects. If successful, the fans should spin up. Further troubleshooting would require testing with a replacement battery or testing components on the main logic board.
さんによる
コメントを追加
回答を追加する
Chris さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 64
