メインコンテンツにスキップ
2021年8月にFlip3と同時に発売されたSamsungのプレミアム折りたたみ式スマートフォン Galaxy Z Fold3の修理ガイドと分解情報です。
21回答 すべてを表示
The 2 Screens not always working
I dropped my phone
The front screen didn't work, but the inside screen worked. I used the tap and massage the phone technique. The outside sceen now works, but the inside screen doesn't work. If I partially open it, I can get the screen to work intermittently. But once it's about halfway open the screen doesn't respond. I opened the phone to see if reconnecting the ribbon cables would work, or if I could find anything loose. I tried clearing the cache in safe mode. I've tried taping and massaging it more, no difference.
Is there a board or cable that I can replace, that might be a likely culprit? Is there a diagnostic software I could use to find the faulty part? Or any other ideas?
Thanks Dan Mayer
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Sounds like the display is the culprit here. Unfortunately, these devices are an expensive fad. While I think it's super cool that we've made a foldable display, it's nothing more than a gimmick to get you to buy a device that's twice as expensive to not only purchase, but also repair, with a higher failure rate.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Both displays functioned after the drop, just not at the same time.
さんによる
コメントを追加
回答を追加する
Danmayer2d さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 33
今までの合計 375
