メインコンテンツにスキップ
初代Mac ProはIntel Xeonをベースにしたワークステーションコンピューターです。初代モデルには2006年から2008年のデバイスも含まれます。
How do I replace the lower optical drive on a MacPro?
I would like to learn how to replace the lower optical drive in my 2007 MacPro computer. There is a power supply behind the optical drives. Additionally there is a metal bracket with square/retangular cutout in front between the door and the optical drive. I don't want to start pulling without specific knowledge to avoid damaging components (ask if you don't know with electronics rule). I have seen some demos for the older PowerMacs but the configuration of the parts is clearly different. Can you advise me.
Kind regards,
Drake
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
For some reason they do not have the picture of a MacPro. AnyWay: The drive is easy to put in. When you get your IDE optical 5.25 drive, you will take the drive door off the drive. Then you shutdown and open your MacPro side door. Make sure the door lock on the back is fully up. Pull the optical bay try outwards. It should slide right out. You can tilt it to remove the cables on the top drive and then pull it the rest of the way out. Install the lower drive you prepared and fasten in with the screws mounted on the drive mount. If none use the screws that came with drive. Place the drive tray back near the opening and attach the cables, including power. Slide the tray back in until it seats. Put the side panel back on and lock the latch in back. Boot up. There will be a new item on your menu bar to the left that you can use to eject the top and bottom tray.
If you need to load software for the new drive it is better loaded before you start the install. Piece of Cake.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
another up vote, but not for research, for experience
さんによる
Thank you for your detailed answer. The reminder to remove the door while on before removing the drive was particularly helpful.
Drake
さんによる
コメントを追加
回答を追加する
Drake LaFace さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 7
今までの合計 4,181
