メインコンテンツにスキップ
2017年に発売された「Dell Vostro 15 3568」は、内部にインテルのプロセッサーとオプションのAMDのグラフィックカードを搭載したビジネス向けのノートパソコンです。15インチの画面を搭載し、解像度は1366×768ピクセルです。
8回答 すべてを表示
Laptop seems to be completely dead.
It doesn't turn on, even the power on light doesn't blink. Tried a lot of stuff shown online like pressing the power button for 15-20 seconds but nothing works.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi @akashpadmukh
Check that the laptop charger has 19.5V DC on the charger cable's output plug, just in case it's a faulty charger/charger cable.
If the charger is OK then there may be a problem with the DC-In jack in the laptop. (supplier example only)
What can happen is that sometimes the inner connector of the jack, breaks internally and opens the +ve power supply path between the charger and the motherboard. This means that the motherboard receives no power and also the battery can't be charged either.
You would need to open the laptop and check that there's continuity between the DC In jacks +ve and -ve input and the wires onthe plug that connect to the output side of the jack.
Here's the owner manual for the laptop.
Go to p.37 to view the procedure to remove/replace the power connector port (aka DC-In jack) so that you can gain access to the jack cable and unplug it from the motherboard so that you can test the jack with a meter.
If the jack is faulty it cannot be repaired, it has to be replaced. Search online for Dell fwgmm to find suppliers that suit you best.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Akash Padmukh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 144
