Recover deleted software?
My iPod shuffle model a1271
and i deleted its software by mistake, including the voice messages and every thing , is there anyway to recover it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
sashi kumar dubey, you can try to place your iPod in diskmode (DO NOT SYNC). Once you have it show up as an additional disk drive, see if you can use a undelete program to see if you can recover some of the files. It may not work if you have synced your iPod after you delete those files. This will show you how to put it in disk mode. Hope this helps, good luck
このアンサーは役に立ちましたか?
Hey! use a data recovery software to recover your data. Don't worry you will get back your all the data. Go online you will get the software in both free and paid versions , use it as per your requirement. You just need to download the software from the site and follow the mentioned steps to recover your data.
このアンサーは役に立ちましたか?
Yes, you can use iPubsoft iTunes Data Recovery that supports the recovery of Voice Memos, videos, pictures, call list, eBooks from iPhone. It allows you to extract and preview your iTunes backup data the selectively recover your voice memos. If you are suffering from the same trouble.
このアンサーは役に立ちましたか?
If you are not satisfied with online softwares or you are not able to recover the data by own then you can also try for Data Recovery Service Provider Company. They can recover your all lost data
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,018
