メインコンテンツにスキップ
Samsung's third iteration of the Galaxy Watch with a newly integrated BioActive Sensor. It was released August 27th, 2021. Model SM-R860, 40 mm, non-LTE version.
Can the battery be replase with longer lasting one
Can the battery be replase with a longer lasting one
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@kennethmil87767 there really are no larger capacity batteries for those. You may find some advertised but reality is, that you can only "squeeze" so much storage into that size of battery. If you find that the performance of your watch has decreased, and the battery just does not seem to last as long, check all of your settings and minimize others "apps" and uses. After that, you may need to consider a new battery, but there won't be much difference between a standard one and "high-capacity" advertised batteries (other than price).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kenneth Miller さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 13
今までの合計 141
