My tablet screen fell off and my ribbon broke how do I install it back
Hi @faricawong
The screen will have to be replaced as the cable connection between the screen and the connector can't be fixed.
You should be able to re-use the flex cable that is plugged into the connector from the motherboard though
Here's the ifixit Samsung Galaxy Tab A (2019) Screen Replacement guide that may help.
Search online for SM-T510/SM-T515 LCD display (if either of these model is your tablet) to find suppliers that suit you best.
このアンサーは役に立ちましたか?
Better pictures would help, the screen should be able to lift to 90 degrees to get better pics of the connector. Plus if it’s off why not remove the screen?
過去 24時間: 4
過去 7 日: 29
過去 30 日: 117
今までの合計 1,224
7 件のコメント
Hey their Farica, when you say that the ribbon broke, do you mean the ribbon cable for the display? Also, some photos would be very helpful for determining the savoriness of the issue and helping you achieve a solution. iFixitでの質問に画像を追加する方法
Jacob Mehnert さんによる
@jmehnert i was just gonna ask for photos
what happened that caused the screen to fall off?
timtom77 さんによる
@timtomissus the tablet overheated so the glue wasn’t holding the screen anymore one day I was watching my tablet sideways and it just fell off and I couldn’t turn it on anymore
Farica Wong さんによる
@jmehnert yes I went to the repair store and the person said it couldn’t be fix because the ribbon broke so I thought it’s impossible that just because the ribbon broke it’s not fixable anymore so that’s why I’m here asking for help
Farica Wong さんによる
@faricawong usually a ripped cable means a new display. Let's see the damage. Post a couple of good photos with your QUESTION. You wil need to edit your question to add images iFixitでの質問に画像を追加する方法
oldturkey03 さんによる
2件以上のコメントを表示
