メインコンテンツにスキップ
北米で2010年3月に発売されたニンテンドー DSiの大型版モデルです。ほとんどの修理作業はドライバー一本と開口ツールのみで完了できます。
157回答 すべてを表示
Blinking Orange Light Fixed Itself?
So I recently acquired a DSI XL from a garage sale where it has previously just been used by the owner’s kid. It had a few little scuffs but nothing major and all buttons and screens work perfectly. I’d already charged it about 3-4 times to full battery since I’d been using it to play old Pokémon games, but today I found the light blinking orange and then it took longer than usual to power on. It’s currently charging again and isn’t doing it at the moment but I’m worried that something might be wrong. Any help would be appreciated since I keep seeing everywhere the a blinking orange light is like a death omen for DS’s.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It should be fine, if you begin to have troubles again, the most likely culprit is the battery.
Try removing and reconnecting the battery.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Yah I’ve begun to have issues with moving the DSI XL. It’ll be fin but if you jolt it too hard it’ll just turn off completely. I tried to tighten the housing case on the battery which seemed to help a bit, but if it’s too hard of a jolt/movement it’ll still turn off. The battery is the original one and it looked perfectly fine including the all the contact points.
さんによる
コメントを追加
回答を追加する
Miss Wiver さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 14
今までの合計 83
