メインコンテンツにスキップ
PlayStation 3 (PS3)はソニーコンピューターエンターテイメントによって製造された3世代目の家庭用据え置き機で、PlayStation 2の次世代機となります。これらは2006年11月11日に発売されました。
783回答 すべてを表示
My ps3 wont spin disks. how do I know what to replace?
i got a faulty ps3 for cheap and everything's fine except when i try to play disks. they get accepted and the icon shows up but they wont show up on the ps3. i dont know whether i need to replace the lazer or the motor. any help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
It's most likely the laser that is faulty but to replace the whole drive is much easier especially if you don't have to much experience. Either way it is a relatively straight forward job, lots of videos online and most likely tutorials on this site. You can buy the drive as a complete kit online, you just need to swap the board at the bottom of your faulty drive to the new drive.
Also to note, if the warranty stickers have been removed then there is the possibility that the drive board I referred to above has already been swapped out and the one installed isn't the original and therefore even if the laser was replaced it all wouldn't play a disc.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It maybe that the laser diode has faded and needs replacing, but other methods may get the optical pickup working again. Try removing and replacing the ribbon cable at the optical pickup (laser) end (I've seen this work). Or try adjusting the miniature potentiometer(s) a fraction in either direction and put the dial back to exactly the same position (better still, measure the resistance so you get it precise). Could use a drop of electrical contact cleaner. (I have heard this works but never tried it)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
kian hughes さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 7
今までの合計 38
