メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
20回答 すべてを表示
Keyboard and trackpad issues
Original task: replace the battery in computer A. When done, the keyboard worked, but not the trackpad. I happen to have a spare MBP (computer B), missing only the trackpad cable. Verified that trackpad and keyboard in B worked with cable A. Swapped trackpads: computer A, with cable A and trackpad B - neither keyboard nor trackpad worked. ordered new trackpad and 2 x cables. A with new TP and cable: keyboard works, not trackpad.
Does anyone have any ideas? Tearing my hair out....
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Not sure exactly what's causing this, but here are a few things you can try. First, reset the SMC and the NVRAM. Next, inspect the condition of the receiving connector for the trackpad cable on the logic board. Does it look clean and free of debris? Is the trackpad cable fully seated in the connector on the logic board and in the connector on the trackpad? Are both of the connector clasps in the closed position when the cable is inserted? Can you control the cursor with an external mouse connected? Is there any visible damage on the main logic board? Is the computer connecting to any Bluetooth devices nearby (it may be set to ignore input from the trackpad if it is connecting to a Bluetooth mouse or trackpad)? Have you verified that the keyboard cable is fully connected to the logic board and that it and its connector are clean and in good condition? These are a few things you could check. Best of luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
David さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 21
