Lens does not retract or respond to tele or wide
@jeffreyfoddy sounds like you are dealing with a stuck lens. Go through some of the things to do, as suggested on here If none of that works, you may need to look into replacing the lens. Here is the service manual that will show you how to disassemble and replace the lens if needed. DSC H2 SM
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 33
