メインコンテンツにスキップ
A tablet developed by HP in 2011 running the webOS platform. Boasts a 9.7" display, and is available in 16 or 32 GB. Repair is straightforward, but requires time and persistence.
How is the lcd backlight powered
I'm trying to repair my Touchpad from a water spill. The digitizer and lcd seem ok and are responsive. The screen doesn't light however. Does anyone know where the backlight is powered from (maybe lcd cable or some other contact on the board) or if it can be replaced if needs be?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
i'm afraid that the backlight power is on the same wire with the screen. So if there is a problem with the backlight means that you have to change your screen to fix it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Mark Turner さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 898
