メインコンテンツにスキップ
Can you change the gpu on an acer Aspire 3?
Can you change the gpu on this laptop?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Hey there, I updated your question a bit to add a little bit more clarity.
さんによる
コメントを追加
2件の回答
To put it bluntly, no. To put it not as bluntly, the issue with upgrading most gaming laptops is that components like CPUs and GPUs are typically integrated directly into the motherboard. This makes upgrading these specific components difficult. Normally I would suggest using an eGPU, however, it does not seem that the Aspire 3 has Thunderbolt support.
I also saw some of your other questions. You can also speed up your machine by upgrading the RAM and an SSD.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
yeah, you can't unfortunately, it even says it on the acer website https://community.acer.com/en/discussion...
hope this helps!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Hello さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 25
今までの合計 574
