メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Released in April 2020, identified by model number 26699-989-999-01
My Headband broke, now it flexes way too much
Hello Dear People,
I think I dropped my Evolve2 Headset, since then my headband flexes at the spot where the silicone patting and the plastics of the headband merge.
I want to take it apart but I´m a bit insecure about how to do this.
Has anyone any experience?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
6 件のコメント
@lukaslobuescher some of the "headbands" really can't be completely disassembled. It might help if you post some good pictures of what you got going on there, with your QUESTION. That way we can see what you see. Adding images to an existing question - iFixit Repair Guide
さんによる
Hello oldturkey,
thank you for the answer!
I thought I already did upload the pictures...
Here they are
さんによる
Yes, mine did the same. I designed and printed a 3D reinforcement cover. Seems to work well on both sides.
さんによる
I have the same issue. I was googling for a while and found no take apart diagrams. Additionally, I couldn't even find any headband replacement as service part (there is always the option to look for broken ones and cannibalize it, but that will give a less working span for the headset...).
Is there any update on this topic?
さんによる
same issue here. Anyone brave enough o open and try to fix it?
さんによる
1以上のコメントを表示
コメントを追加
2件の回答
最も参考になった回答
I got mine apart and found a white plastic piece broken at the flexing portion. Either need to find a replacement or use JB weld to strengthen it? Not sure. Was not too hard to come apart, trickiest part was removing the curved plastic piece nearest the earpiece from the flat plastic. Use small flat blade and get between flat and curved area moving the curved portion away out and away from the flat area. It has clickable locking tabs. I might update this if I get this thing glued...
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
@richardp78529 If you can somehow give us the STL file for your 3D printed part, I would love to try and/or modify it. Thanks, Kirk Reed
さんによる
@KIRK REED, please keep us up to date on your progress.
さんによる
Hi Kirk, Were you able to fix the part?
さんによる
No I still have not had time... I guess others are having the same trouble? All the parts are still in a bag waiting. I was hoping someone would desiugn a replacement part for the inside or some kind of outer 3D printed part to clamp onto the band to replicate the function of the inner part. That inner part is somewhat fragile, maybe a beeier larger part can be applied to the outside structure that looks nice enough...
I actually bought and used a new tube(s) of JB Weld last night. I should try to use it before it gets old...
さんによる
コメントを追加
I have the same issues. I ended up using clear tape on mine. I just ordered the a new pair. The Evolve2 65 Flex. They must knew about the issue because they built it different this time.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lukas Lobüscher さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 38
過去 30 日: 143
今までの合計 1,958
