My phone does not show network bars. how can I repair it?
my sumsung A8 star does not show network bars on the screen. how can i repair it?
Try resetting the network settings and check if that restores the airplane functionality so that you can connect back to your network
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 57
5 件のコメント
Hi @maph,
Try turning airplane mode on and off to see if this resolves the problem.
jayeff さんによる
is it getting cellular service, and not showing any type of bars or anything at the top of the screen, or is there no bars and no cellular service?
if it is getting cell service, i think you should mess in settings and see if you can get it to pop up
timtom77 さんによる
@timtom7777 it only receives cellular service but does not show any type of bars at the top, could you get into specifics when u are talking about the settings please
@jayeff hw are you......
well about the airplane mode still there is no difference
in the meantime the airplane mode its highlighted but its not on.
maph さんによる
@maph
So turning airplane mode on and off doesn't change the notification icon that it is still on, is this correct?
Is the airplane enable/disable setting working or greyed out?
jayeff さんによる
@jayeff
yes that's correct
it's greyed out and disabled
maph さんによる
