メインコンテンツにスキップ
Released August 30, 2019 with a resolution of 240 × 320 pixels.
Why is my keypad not working?
Keypad 789 is faulty
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 7
2 件のコメント
phone dead please my prv solution my mobile itel ace my mobile water damage
さんによる
Dissemble the phone's keypad
And then, open the button then you clean all the dust and debris it's components carefully without and further damage
さんによる
コメントを追加
1 件の回答
ベストアンサー
@ransonmugalla take a look at this guide Itel 2163 Disassembly - iFixit Repair Guide Step 4 (not the greatest images but it should work) shows the membrane and the contacts for your keypad. Clean the membrane and the contacts with an eraser. I like to use the erasers that are at the end of a pencil. If that does not work for you, check ideas like this one as well as on here for a deeper repair. Looks like this is a common issue with that model.
While you work on your phone and repair the keypad, take lots of good pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
このアンサーは役に立ちましたか?
スコア 7
コメントを追加
回答を追加する
Ranson Mugalla さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 50
今までの合計 1,190
