Bad board or display?
I was watching my m558-g1 and left the room, when I came back the screen was lit up but and moving around but it was just bars of color. After some troubleshooting the logo will display clearly at boot, but then fades, I also was able to see it display the TV name and input temporally.
I took the boards out for visual (but very amateur) inspection, the only board that looked a little off was the "main" board with all the inputs on it. There is some slightly amber coloring on some of the pins and contacts. Pics below.
Could this be a failing board issue vs display failure? To me it makes sense but I'm biased and want it to be a board, since it doesnt mean I need a new TV.
What works:
Ir sensor &physical tv buttons
Internet connectivity (vizio updated firmware remotely)
Back light (vertical colored bars)
Audio
Hdmi input
New pics:
Multimeter test:
この質問は役に立ちましたか?
1件のコメント
Did you ever try replacing one or more of the boards? I’m having this same problem, would love to know if anything worked.
Nora McBurnett さんによる
