メインコンテンツにスキップ
Appleの主要モデルである2021年のiPhoneは、9月24日に発売され、6.1インチの有機ELディスプレイ、デュアル12MPカメラシステムを搭載し、5色のカラーバリエーションが用意されています。iPhone 12の後継モデルです。
97回答 すべてを表示
My phone charger is crooked
So, my lightning connector is crooked. It's not bent forwards or backwards; it's literally off center just a tiny bit. However, that tiny bit is causing my phone to not charge and it's making me slightly upset because this is a brand-new 10ft charger that I've had for less than a month and has just recently started happening.
It's not the charger port because I have already checked for lint and all of that fun stuff. How do I get my connecter straight without taking apart my cable so the pins and everything can line up?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
First, check if there is any dirt in the charger port if not then the cord may be broken.
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
The cord works fine and there is no lint in the charging port. The connector itself is about 3 millimeters off-center and I want to know how to straighten it out.
さんによる
@anniebentley Can you send a picture of the charger cord in the phone and out of the phone?
さんによる
My phone, unfortunately, died, so I am unable to take or send any pictures. I'm writing this out on my computer.
さんによる
@anniebentley You should try a new OEM apple cord then?
さんによる
@anniebentley if you have someone you know with a samsung phone that supports wireless charging, you can charge your phone by putting it on the back of their phone (im saying this as im assuming you don't have a wireless charger, but its another way to charge your phone and upload photos until you fix it)
さんによる
コメントを追加
回答を追加する
Annie Bentley さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 99
