メインコンテンツにスキップ
PlayStation 3 (PS3)はソニーコンピューターエンターテイメントによって製造された3世代目の家庭用据え置き機で、PlayStation 2の次世代機となります。これらは2006年11月11日に発売されました。
783回答 すべてを表示
PlayStation 3 blank screen, can’t get into reset screen.
Hi, last time I turned on my PS3 it worked fine. Nothing has changed since, using the same TV with the same cables etc.
Now when I turn it on I get a blank screen, have tried different cables, including the component cable that came with the PS3 in different ports.
I have tried the reset by holing down the start button until you get the 2 beeps, with both HMDI & component cable in different ports in the TV, but still just get a blank screen.
Can anyone please suggest anything else I could try??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It sounds like you have already tried some basic troubleshooting steps, such as changing cables and attempting to reset the PS3. Here are some additional suggestions you could try to get your PlayStation 3 working again:
Check the power supply: Make sure the PS3 is properly plugged into a power outlet and that the power cable is in good condition. You could also try plugging the PS3 into a different outlet to see if that makes a difference.
Test with another TV: If possible, try connecting your PS3 to another TV to see if the issue is with your TV rather than the PS3.
Try a different display setting: Sometimes the display setting on your PS3 can get changed accidentally, causing the screen to go blank. Try changing the display setting to a different option, such as 720p or 1080p, and see if that fixes the problem.
Remove any discs or USB devices: If there are any discs or USB devices inserted into the PS3, remove them and try turning on the console again.
Boot into safe mode: Try booting your PS3 into safe mode by holding down the power button until you hear two beeps. From there, you can try restoring the file system or rebuilding the database.
If none of these steps work, it may be time to contact Sony customer support or take your PS3 to a professional repair shop.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi, thank you for the advice. Can you please advise how I change the display settings if I have a blank screen?
さんによる
コメントを追加
回答を追加する
M Draper さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 16
今までの合計 126
