メインコンテンツにスキップ
Moto G4 PlusはMotorolaのMoto G4モデルの改良版です。Moto G4 Plusは指紋センサ、増量したメモリ容量、改良されたリアカメラが搭載されています。モデル番号はXT1642とXT1644です。
73回答 すべてを表示
My display remains greenish all the time
Recently I has dropped my phone into water then the camera module get moisture. That time I was very hyper then took it to a phone servicing centre and clean the moisture but the display got tint issue......and also ghost touch issur.....my display remains greenish all the time .. what can i do now??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@srtechente59078 At this point the most obvious solution for you is to replace your screen. Since both the LCD and the digitizer are contained in the display assembly, replacing it should solve all of the problems you're seeing.
The good news is your prompt action with getting the phone cleaned probably saved it, but displays are notoriously sensitive to liquid damage.
Replacing the screen is something you can do yourself, but if you're not comfortable then you'll want to take it to a service center to have the repair done. Here's the iFixit guide that will take you through the procedure step by step.
Motorola Moto G4 Plus LCD Screen and Digitizer Assembly Replacement - iFixit Repair Guide
You can buy a replacement screen right here on iFixit or go shopping yourself on places like Amazon, eBay and AliExpress.
Moto G4 Plus Screen: LCD Display + Digitizer Replacement Kit - iFixit
If you don't have the tools already, I'd recommend the Fix Kit version. For an extra $6 USD you will get all the tools needed to open up the phone, remove all the internals and replace them into a new display, along with all the adhesives needed to put the phone back together again.
Moto G4 Plus Screen - Genuineの画像
製品
$29.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
S&R Tech& Entertainment さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 10
