メインコンテンツにスキップ
4インチディスプレイ/カラーバリエーションは様々あり/3種のモデル/16, 32もしくは64 GB容量
Why does my iPod say the battery is dead?
I replaced the battery in my iPod touch. Before reassembling it, I made sure it turned on and everything was fine. When I reassemble it, there is no power and it says the battery is dead.
Every time I tear it down it powers on, as soon as I put the security plate on, it shuts off and says dead battery
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
It turns out it was the home buttons ribbon cable. I'm not entirely sure what exactly was happening, but when I closed the aluminum plate while the ribbon cable was pulled through it, the whole iPod would cease functioning. I cut a little strip off the plate for the ribbon cable to sit freely, and it works perfectly normal once again :)
Thanks for all the replies and help!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Hi
It sounds like you might have a issue with the solder joints on the battery
Here’s what to check
Make sure that the battery’s cable is as flat to the board as possible,make sure all 3 pads are solid and aren’t coming off easily…I would pay close attention to the middle one as that one has a lot todo with charging the device
And last I would check that you have insulation over the contacts for the cable to make sure nothing is shorting out:-)
After that it could be a bad battery
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Greetings, I had this problem.
Basically It has to do with the middle pad on the battery, It plays the role as the current charge signal. (So it can tell what % the battery is at)
@hellomacos Can help you I bet!
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
I'm sorry, I don't know what you mean by middle pad. Do you mean the centre solder of the three connections? I don't see a pad anywhere 😅
さんによる
@levikwiatkowski - No it's my fault!
I should have been more clear!
さんによる
I'm terribly sorry, but I still don't follow.
Is there something I can do, or do I need to replace something ?
さんによる
@beanman56
Thanks for tagging me in!
さんによる
コメントを追加
回答を追加する
Levi Kwiatkowski さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 28
今までの合計 216
