Can you over clock a Xbox 360?
How could you if it were possible?
You could probably alter some frequencies if you hack it and rewrite system or SMC firmware, however it probably just break things instead of actually providing any benefit.
このアンサーは役に立ちましたか?
Is there any way to make it go faster?
@nytryder26 define faster.
@tomchai I there anything I can do to make it stop it from freezing up?
@nytryder26 Freezing up has nothing to do with being fast or not, your board has a stability problem now.
@tomchai Well is there anything to make it speed up?
Absolutely! Overclocking an Xbox 360 is definitely possible, and can provide a thrilling boost to your gaming experience. However, it is important to note that overclocking can also lead to a number of risks and potential problems if not done correctly.
To overclock your Xbox 360, you'll need to modify the console's internal settings to increase its clock speed. This can result in faster processing times and smoother gameplay, as well as better graphics and frame rates.
If you decide to overclock your Xbox 360, make sure to do so carefully and with the help of a qualified technician. With the right precautions and expertise, you can enjoy an exciting and enhanced gaming experience like never before.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 26
今までの合計 464
