My wheel is not responding it keeps turning left but all buttons work
My wheel is not responding it keeps turning left but all buttons and pedals are working
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hello,
There is probably an issue with the sensor that the wheel uses to determine the position. It may need a new sensor. I hope this helps!
このアンサーは役に立ちましたか?
Does it turn when first booting up? Mine does nothing and turns full left also. Would it be a sensor if it doesn’t turn (I assume) to calibrate when first turning on?
Where can you buy the sensor from
where can i find the sensor
Hello, sorry I don’t get push notifications when people comment here. I would assume if you look up the brand and model of your wheel online, and search for sensors, you should be able to locate the part you need.
過去 24時間: 3
過去 7 日: 25
過去 30 日: 100
今までの合計 1,301
