メインコンテンツにスキップ
2020年4月に発表、発売された第二世代iPhone SEの修理と分解情報です。
243回答 すべてを表示
SE2020 non-genuine battery message
i'm trying to get around that non-genuine battery message for the SE 2020.
i have a JC V1SE programmer, i did the read/restore process, i did the copy/write 4item process. i did the BackupData/WriteData process.
the battery works fine, but the pop-up message is annoying and the lack of the battery health percentage is not helpful. i rehab phones as a for-profit hobby and not being able to make this message go away can sharply impact resale values.
what am i doing wrong with my V1SE?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi B C,
What are you doing wrong? Probably nothing. Apple has continued it's repair-antagonistic direction with now pairing batteries to logic boards. It's my understanding that the non-genuine battery warning started with the XS and the only way to get rid of it is to swap the BMS to a new battery cell. It appears that may apply to the SE 2020 even though it's closer to the iPhone 8 in its lineage rather than the XS, but I don't have any definitive answer so far. Aftermarket vendors are offering SE 2020 cells without the BMS, which implies that swapping is necessary, or at a minimum it's being done often enough to justify offering the bare cells as an option.
To make matters worse, as of the iPhone 11, the battery health information is encrypted and cannot be reprogrammed on the original battery boards. Manufacturers have come up with a workaround for now that involves adding a small circuit board called a tag-on board that connects between the battery and the motherboard and allows you to write the battery data. That board has to be left in the phone permanently but could be reused should the battery need to be replaced once again in the future.
Sure wish they'd quit making life miserable for those of us who are perfectly capable of opening up a phone and replacing a battery!
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
@dadibrokeit,
Hi Jerry,
thanks. so do you know what all is involved in swapping that BMS board on the battery?
さんによる
@beekerc It's fairly straight-forward; you pretty much just cut the old battery board off and solder or spot weld it to a replacement cell; you can buy them without the BMS like this one.
https://www.injuredgadgets.com/xcap-batt...
Spot welding is recommended to minimize the heat that the cell is exposed to, but if you're quick and careful a soldering iron will work fine. Here's a video showing the use of a soldering iron.
https://www.youtube.com/watch?v=-03NBLci...
If you want to get all altruistic on us, you could do a guide on this whole procedure!
さんによる
コメントを追加
回答を追加する
B C さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 31
過去 30 日: 149
今までの合計 1,623
