メインコンテンツにスキップ
モデル番号A1318/ 32もしくは64GB容量
299回答 すべてを表示
Worked fine after lcd/digitizer replacement untill this morning.
I replaced a busted lcd & digitizer on an a1318 iPod touch 3g last night... Everything was working beautifully! Left it to charge overnight, and when I got up this morning, it will not power on nor does the computer make a 'connected' sound when plugging in the usb cable. Tried a hard reset to no avail. Any thoughts would be GREATLY appreciated!
Thanks in advance!
~Rob
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
Hey Rob,
It sounds like one of the connectors probably wasn't connected all the way and came loose while you were using it. Try opening the device back up and checking all of the connections, especially the one that connects to the dock connector ribbon cable.
Hope this helps! Let us know how it goes; good luck!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for your reply! Tapped it on my knee a couple times & it started working again... Opened it back up (since the tapping isn't a permanent fix) and discovered a broken solder point on the battery connection... Works fine now after fixing the broken contact. Thanks again for your help!
さんによる
コメントを追加
Check ur connections
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Rob さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 676
