メインコンテンツにスキップ
The Galaxy A12 is a low-end slate Android smartphone released by Samsung in November 2020 as a successor to the Samsung Galaxy A11. Identifiable by model number SM-A125 (followed by version/carrier-specific character.
I hit my phone on my room carpet
Ok so I raged and lightly slammed my phone on my room carpet and now every time it turns on its glitches out and the screen goes black my phone does have cracks and hit the ground many times, but this never has happened to me before and now it won't even turn on and won't appear when I plug it in a computer, and it won't charge can someone pls help me. Also, I do hear the click when I press the volume down button and the power it used to turn it back on but know I will not work.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
well, you definitely slammed it down pretty hard, as you either knocked a couple of connectors lose in the phone, or completely shattered your lcd to the point where it stopped responding and knocked loose your charging port, i would recommend opening your phone to see if its just a few connectors loose, or if there are other issues. also i would recommend getting a new screen
https://www.amazon.com/Samsung-Replaceme...
also any photos would be nice!!
iFixitでの質問に画像を追加する方法
follow this to take off the screen to see what is wrong
[無効なガイドリンク]
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Thank you timtom7777 but which connectors would be loose also my phone did work last week and even charge and show up on my computer but did glitch out time to time but now it will not turn on
さんによる
well, that would depend on where it hit when it landed on the ground
i would assume a lcd or battery connector might have been knocked loose if it isnt that, then the screen is cracked past repair and you need a replacement.
https://www.amazon.com/Replacement-Digit...
さんによる
@timtomissus Thank you I slammed my phone at the bottom my think I knocked a battery connector loose also can I use a knife to open up my phone.
さんによる
@trevionoglesby No, use proper prytools.
さんによる
コメントを追加
回答を追加する
Trevion Oglesby さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 120
