My Ticwatch pro Not charging and not powering
Greetings, my Ticwatch pro isn't charging and not powering as well. Kindly help.
Thanks
Hey, Hillary
I'd suggest the obvious approach replacing the battery in your smartwatch. If you've already tried that or it doesn't end up working, make sure your current battery is properly seated and connected.
このアンサーは役に立ちましたか?
I have the ticwatch3pro ultra gps
after i was swimming in the pool, i had the same Problem
could IT bei that I have an water damage ?
このアンサーは役に立ちましたか?
I had the exact same problem! not sure what to do as I've bought mine 2nd hand
過去 24時間: 1
過去 7 日: 15
過去 30 日: 73
今までの合計 624
