メインコンテンツにスキップ
Designed for long-lasting performance, this laptop has a long-lasting battery. Has an AMD Athlon Silver 3050U Dual Core Processor, 4GB RAM, 128GB SSD, and a rich HD display. Do it all, all day.
4回答 すべてを表示
How do I remove a Stripped GPU Heatsink
Not the same laptop since i cant find mine but its a 15s-du3502TX they all have the same kind of internals. Anyways i stripped a GPU heatsink while doing my yearly repasting this is the first time this happend. Did some methods varying from superglue ,steel wool , duct tape , and begging. Really dont like going to the repair shop since they are not trusty asf and may damage my laptop even more
Suggestions like power tools are not an option due to me not having any of those.
Any kind of help is appreciated
Update (03/28/23)
Can i also know the screw size thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @olift
As best that I can find out the laptop (HP product number 46R38PA check the info label on the bottom of the laptop to verify), belongs to the HP 15-dw3000 (1A3Y5AV) series. (see here and here and note the product number.
Looking at p.47 of the maintenance and service guide taken from the support webpage for the HP 15-dw3000 (1A3Y5AV) laptop series it states:
"Discrete graphics: In the order indicated on the heat sink, remove the six Phillips M2.0 × 2.8 screws (1) that secure the heat sink to the system board"
The manual also states that a Phillips P1 screwdriver is used for the removal of components in the laptop.
The parts list above shows a screw kit - part # L52043-001 (supplier example only) but it may be a bit much to pay for just 1 screw, which may be available from the local hardware store.
As to how to remove the stripped screw you could either try using a set of screw extracting pliers or perhaps a screw extractor (examples only)
Hopefully this is of some help.
Precision Screw Extractor Setの画像
製品
$24.99
Screw Extracting Pliersの画像
製品
$19.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
o LiFT さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 166
