Phantom paper jam error message won't clear
Hi
My Epson ET-2800 series printer says there is a paper jam but there is not. I cannot get it to clear this message so it will not print anything.
Thanks
M
この質問は役に立ちましたか?
Hi
Thanks
M
この質問は役に立ちましたか?
Over time paper dust can collect covering the optical sensor so it thinks paper is jamming things up. Open the printer as you would for a jam and locate the sensor, a short blast of can’ed air should fix this. If not the sensor it’s self could have failed.
このアンサーは役に立ちましたか?
I tried the blast of air and it did not work. How do I fool the sensor? Where is the sensor in this model?
the model is ET-2803
@cmdoh - Here’s a similar printer Epson Printer Service Manual
You can’t fool the sensor, but you may need a replacement
過去 24時間: 2
過去 7 日: 17
過去 30 日: 68
今までの合計 2,040
