WiFi, Bluetooth and Hotspot not working in my Realme C11
How do I fix them please?
If you're experiencing issues with WiFi, Bluetooth, and Hotspot on your Realme C11, there are several steps you can take to fix the problem. First, check your network settings to make sure that these features are enabled. You can also try restarting your device or clearing the cache and data of the affected app. Additionally, ensure that your device has the latest software updates installed. If none of these solutions work, you can try resetting your network settings or performing a factory reset on your device. However, it's important to note that a factory reset will erase all data and settings on your device, so be sure to back up your important data before proceeding. If the issue persists, contact Realme customer support for further assistance.
このアンサーは役に立ちましたか?
I'm doing all but still same problem
過去 24時間: 3
過去 7 日: 16
過去 30 日: 127
今までの合計 2,055
3 件のコメント
Hotspot is not playing from my phone to desktop
M Pankaj Kol さんによる
Signal lost connection
R Ardiansyah さんによる
To change display
Battery change
Sajan Sabu さんによる
