メインコンテンツにスキップ
MacBook Pro 16インチの解体情報と修理ガイドです。2019年11月に発売されました。モデル番号はA2141とEMC3347です。
Won't power on while battery cable is connected after fan replacement
As title says, I performed a fan replacement, but then the macbook wouldn't turn on. I followed MacBook Won't Turn On and identified that when the battery cable is removed, I can power on while the power connector is plugged in. Obviously there is no battery detected when this happens
Before the fan replacement, battery was in excellent condition and no issue
How should I fix this? Do I need to buy a new connector cable?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
4 件のコメント
So, you only replaced the fan unit you didn’t remove the battery of logic board, correct? Also which fan left or right?
Could you have damaged something in the process?
さんによる
I replaced both left and right fans at the same time.
Of course it's possible something could have been damaged, but I was very careful and followed the official guide. Nothing appeared to be out of the norm
Unfortunately, I'm noticing that when I power on (with battery disconnected) the fans ramp up to 100% very quickly, and kernel_task is using >1000% CPU. I am unable to reset PRAM/NVRAM
Official Apple fans were used for the replacement
さんによる
@aaronmassicotte - the fans ramping up is expected! SMC is going into CPU Safe Mode where it will do this when key sensors are lost, it will also lower the CPUs clocking as well.
What guide did you use?
さんによる
I used https://www.youtube.com/watch?v=IBnmbcZP...
So are you suggesting that in addition to the battery, a temperature sensor was also lost? Or is this simply normal behaviour if the battery is not connected?
Can confirm when running pmset -g thermlog, that CPU_Speed_Limit = 20 and CPU_Scheduler_Limit = 40
**** SMC sensors ****
CPU Thermal level: 255
GPU Thermal level: 100
IO Thermal level: 100
Fan: 5556.93 rpm
CPU die temperature: 32.57 C
GPU die temperature: 35.00 C
CPU Plimit: 40.00
GPU Plimit (Int): 15.00
Number of prochots: 0
Performance Limited Due to:
CPU LIMIT PROCHOT
GPU LIMIT PROCHOT
CU/GPU Overlap: 14.34%
Cores Active: 39.66%
GPU Active: 32.11%
Avg Num of Cores Active: 1.54
さんによる
コメントを追加
1 件の回答
ベストアンサー
@aaronmassicotte - You really need to use a better tool to see all of the sensors. I would use this tool TG Pro
In any case the sensors involved are via the battery so without it your system goes into CPU Safe Mode.
As far as your original issue, I would double check your ribbon cable connections making sure they are fully inserted and straight in with the compression latch set. Could you have damaged one of the cables?
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Aha, yes this is a nice piece of software. Many thanks!
さんによる
So finally what happened was it was the battery ribbon connector. There was a problem with the way it was being inserted. Now everything is showing up as normal and working as intended
Awesome thanks to all the help. Very nice to have the support from a community like this :) Hopefully this thread can save some headaches from someone with a similar panic regarding the thermal throttling
さんによる
@aaronmassicotte - if everything is working, don’t forget to score the answer and accept it - Thanks!
さんによる
コメントを追加
回答を追加する
Aaron Massicotte さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 17
今までの合計 315
