メインコンテンツにスキップ
Asus ROG 15'' ryzen-powered laptop released early 2021.
17回答 すべてを表示
Why did my display turned black after being turned on
After turning on my computer the screen worked fine, when started digging up the web and playing some games as I usually do. Then pc screen started showing me the color bars you would see on old tv's on the laptop screen and then it turned black, after disassembling the computer and cleaning it up, plugging and un-plugging the screen did not make any effect, just that this time the screen would have black backlight. however after some time the screen stopped turning on completely and only worked through the monitor.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @luiseddilc80475
With the laptop on, try shining a flashlight at an angle close to the laptop's screen and check if you can see any images at all.
They will be very faint if they are there so trying this in a darkened room may help to see them.
If you can see images then there's a backlight problem with the display. This could be a faulty backlight power supply on the motherboard, faulty video cable or a faulty screen.
Hopefully you turned off the laptop and disconnected the battery from the motherboard before unplugging and plugging in the screen.
Plugging the video cable back in again if the laptop was on or even if it were off and the battery wasn't disconnected, could've damaged the backlight power circuit i.e. blown a fuse on the motherboard if there is one or perhaps even a power mosfet that supplies the backlight power if there isn't a fuse.
If you can't see any images, then it could be a faulty video cable or laptop screen
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Luis Eddil Calderón Rivas さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 13
今までの合計 884
