メインコンテンツにスキップ
The Bose 3-2-1 Home Entertainment System is a series of DVD-based home media systems in the Bose 2.1 home theater line. The Bose 3-2-1 Home Entertainment System was sold between 2001 and 2006 and was available in black and graphite colors.
91回答 すべてを表示
Is there a s-video cable with regular connector on 1 and and connector
I have 2001 Bose 3-2-1 sys. Need to hook up to new tv. Is there a S-video cable with regular end, and the other end with fitting for new tvs. How can I connect my system? Thankyou
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
@steve37094 it would depend on what make and model your TV is. Most likely it would have component input. Check to see if your Bose uses that too. The Bose II and GS series do have that. Not sure if yours does. If it absolutely does not, you can get a S-video to Component video adapter like this to make it work. Again, we need to know the TV and if unsure about what connectors your Bose may take, post some pictures of those with your question. Adding images to an existing question - iFixit Repair Guide
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
There are s-video to HDMI converter boxes. HDMI is the most common cable on new televisions.
I have not used this device, but it is an example of a converter:
https://www.amazon.com/Converter-S-Video...
Also, S-Video is low-resolution (480p maybe?) so on a big screen TV, the picture may not look great.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Steve さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 36
