メインコンテンツにスキップ
2.3GHz, 2.6GHz, or 2.7GHzクアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大3.7GHz) 6MB 共有L3 キャッシュ付き。
561回答 すべてを表示
Restarting so much time.
Hi , i have a old computer but try to starting so much time, pc not opening just open and close not see a profile page. And i m shut down pc and open repeatly.
Pc give me a notfication is translate for english:
Start panic medi
A third party kernel extension was preventing the machine from booting successfully. All third party kernel extensions are disabled. You can re-enable them in Security & Privacy system preferences when used
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
First, try a PRAM reset. To do this, shut down the computer, then power it on while holding P + R + Option + Command on the keyboard until you hear two distinct chimes. If this doesn't help, then try to boot into Safe Mode. To do so, shut down the computer, then power it on while holding the Shift key. Continue to hold the key until you see the progress bar. Then release the key and see if you are able to boot up and login. If so, login and try to apply any available OS updates. If this doesn't help, you may have a deeper issue and may need some type of hardware repair.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
SH ZG さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 51
