Battery draining overnight even if im not using it
Is it normal that 10 percent is draining on my battery overnight even if im not using it? Thanks for the answer
If it's powered on and not charging... then I'd say yes...it's normal to leave it on for 6 to 10 hours and lose 10% or so of battery. . . especially if its original battery and nearing the end of its life... If it is powered off and not charging, to lose 10% would not be normal... unless battery is defective or in need of replacement or a short somewhere (Most likely wifi ic or the like) and draining battery. What condition is this happening? Also check Battery health in settings to see if its 80% or below...
このアンサーは役に立ちましたか?
I wouldn't be panicking over 10%, I'd be happy. Mine uses 25 -30%. WiFi on, Bluetooth on, mobile data. Its to be expected.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 38
