WhatsApp calls with Bluetooth headset
When I'm using a Bluetooth Headset and I make a WhatsApp call, my friend will stop hearing me as soon as the screen of my phone goes on standby. Have you experienced that before and what can I do.
Set the screen to either stay on longer or not turn off. Be warned, depending on phone you could be causing screen burn by doing it. When the screen goes off it basically closes the app, ending the call so to speak. There may be something in permissions you can change.
このアンサーは役に立ちましたか?
Thank you for your response, that is what i currently do, however, you should note that this is not good for the battery and it can also burn the screen. I will appreciate if anyone knows the permission that can be activated or changed.
Thank you Nigel
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 38
