メインコンテンツにスキップ
第三世代の Surface Pro タブレットは、2014年6月20日にリリース。
Won't turn on - how can I get data?
Hello. Yesterday my surface pro 3 stopped wouldn't turning on. In case it was the battery/power, I tried a couple of different chargers - but both show the pro is charging, and still the screen doesn't turn on. I tried the hard reset by pressing and holding the power button - after about 20 seconds the charger light blinks momentarily before going back to being solid, as if to show the pro is restarting, but still no turning on.
I recently bought a new computer as the pro was getting old, and my concern is not the device, but the data. I last backed up the pro about a month ago. There is data on there I need access to. Is there a way of getting it?
Thank you very much.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @emmie3298
Here's one way which is not that easy but it's doable. Depends how much possible damage to the laptop you're prepared to accept.
Here's the ifixit Microsoft Surface Pro 3のSSD交換 guide that will help.
Once you have gained access to the SSD (that's the hard part) and removed it, you should be able to then insert it into a PC that has a spare M.2 port so that essentially it becomes a storage drive in that PC and retrieve the data that way from the SSD.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you very much!
さんによる
コメントを追加
回答を追加する
Emmie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 9
今までの合計 386
