メインコンテンツにスキップ
The Galaxy A12 is a low-end slate Android smartphone released by Samsung in November 2020 as a successor to the Samsung Galaxy A11. Identifiable by model number SM-A125 (followed by version/carrier-specific character.
20回答 すべてを表示
A12 Screen wont turn on but it vibrates
My phone screen had recently broken so I purchased a replacement screen and had to take out and put back the entire phone (as I mistakenly got one without the frame) after it did turn on and was working, however, I noticed that the selfie camera was blurry so opened it up again to investigate, after that, I put the covers back and now it won't turn on, however, I can feel very often vibrations upon holding the power button. I have already tried to do resets, hold down the volume buttons, etc. Any help will be greatly appreciated
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
3 件のコメント
Samsung A12 only vibrates but not displaying
さんによる
Abram, did you read @jayeff's answer? Have you gone through the troubleshooting steps he outlined? Did you replace the screen? Or did you just come here to complain?
Please try some of the suggestions first and let us know what you found as a result; after you've done that we'll be glad to see if we can help.
さんによる
Screen was on but display not work only seen black
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi @aymenhussain
Check that the LCD display flex cable is securely connected to the motherboard.
Here's an image from the Galaxy A12 service manual showing the Power On troubleshooting flowchart where I've highlighted where the problem may be.
(click on image)
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
not working 😞😞
さんによる
@liliahouamdi,
When you first turn on the phone does the Power On sound or vibrate motor operate OK?
If not you may have to replace the display assembly.
さんによる
コメントを追加
回答を追加する
Aymen Hussain さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 22
過去 30 日: 42
今までの合計 1,912
