メインコンテンツにスキップ
Troubleshooting and Repair for the 32" 1080P LG 32CS560 LCD TV.
47回答 すべてを表示
standby voltage issue chnaged from 3.3v to 8volt
i am just amateur, i have 32" lcd television PCB: EAX64905001 2.4
the standby voltage should be 3.3v
i found the standby voltage now around 7 to 8 volt
that happened after changed Capacitors , ihave return it to original caps but still same issue
any advice please ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@tarekhelal if you show overvoltage on P401 or P404 9-12 pin then you are having a power board issue. You are not telling us where you are measuring, why you are measuring, what your TV does or doesn't do, and why you exchanged the capacitors. All of those details are important for a good troubleshooting .
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
i have messured on output socket to the main board , also unlplugged the mainboard and backlight cable
previously its only show red light
さんによる
@tarekhelal If that is the voltage it shows and the original voltage is supposed to be 3.5V the issue could be a MOSFET or a couple of diodes etc. You will either need to find a schematic for that power board and check the components, or replace the board.
"previously its only show red light" that would have meant that your power board supplied stby power. The error could have been the main board not telling the power board to turn on. Hard to say.
さんによる
コメントを追加
回答を追加する
Tarek Helal さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 55
